TwinTurbo.NET: Nissan 300ZX forum - Re: help, timing belt gear removal
Subject Re: help, timing belt gear removal
Posted by txq45 on April 29, 2009 at 8:17 PM
  This message has been viewed 193 times.
In Reply To help, timing belt gear removal posted by mongooze on April 29, 2009 at 07:13 PM
Message If it doesn't come off with two bars one on each side, then you can use the dremel method.
Grind down between the teeth in effect splitting the sproket. You don't have to completely split it. It will become Loose then you can pull it off either with your hands or a small pry bar on each side.
